Home > Forums > General Forums > CFD Freelancers
OpenFOAM lagrangian particle tracking solver C++ developer needed
Old   April 4, 2016, 10:07
Default OpenFOAM lagrangian particle tracking solver C++ developer needed
Tom Hampshire
hampycalc is on a distinguished road
We require a custom OpenFOAM solver for lagrangian particle tracking. The solver itself should be relatively simple for someone with the correct skills. The solver will take as an input:
  • A precomputed velocity vector map
  • The same set of boundary conditions used for the above
The particles themselves are massless and non-interacting (although they may need some interaction of non-positional properties at some later point). They are simply a discretisation of the underlying fluid, allowing for tracking of temporal properties, which are affected by some external field. The particles' positions will only be affected by the underlying velocity map, which is pre-computed.
The solver should allow:
  • Arbitrary properties to be easily included (into the particle class)
  • Easy integration of injection models (this will likely be on a patch)
  • A cell-zone initialisation of particles (so an initial [time = 0] volume are filled with particles
This project will likely have parallels with the post processing streamLine functionality of OpenFOAM.
Code will need to be well documented and written to a high standard. This development work is needed asap, so please contact us if you have the required skills.
hampycalc is offline   Reply With Quote
Old   May 18, 2016, 08:46
Ravikumar Ajjampudi
cfdravi is on a distinguished road
Dear Tom,
This is Ravi from ESI-Group. You may be aware that OpenCFD (openfoam.com) is now part of ESI and the development team can help you out, if you are interested. Please visit this link http://openfoam.com/services/development.php
Regards
Ravi
cfdravi is offline   Reply With Quote
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message peteryuan OpenFOAM Installation 6 August 18, 2013 18:00
Lagrangian Particle Tracking model In CFX Kushagra CFX 8 December 2, 2010 21:18
cod for lagrangian particle tracking mazdak Main CFD Forum 2 December 29, 2009 02:53
