Simulating Capillary Effect in a heat pipe wick |
February 26, 2019, 05:05 |
Rahul Ruia
Rep Power: 7 |
I am doing my 8th semester project on heat pipes.
My project mainly involves simulations on ANSYS. I have successfully modelled and meshed ( which is the easier part), I am struggling to incorporate the capillary effect in my wick structure. The heat pipe which I have modelled is a closed system, it contains a vapour flow region enclosed by a wick structure. The wick structure is in turn enclosed by a copper casing. I am using the VOF model into incorporate the multiphase effects, along with the K-Epsilon model . The main problem I am facing is on how to incorporate the capillary effect. I am currently running a simulation with the following settings in the porous zone :- 1) Homogenous Porosity of 0.55 2) I am using only viscous resistance as the flow in the porous region is laminar. I have 3 fluids namely air, water and steam. I have given the same values of viscous resistance for water and steam and higher value for air ( I did this because I did not want air to flow in the porous media). 3) I reversed the direction vectors from 1 to -1 hoping that they will lead to incorporation of the capillary effect. I am running short of time and am in need of help. I am willing to pay, if someone helps me solve my problem. PS : please mail me at ruiarahul5@gmail.com ( for further information) |
March 10, 2019, 11:32 |
I think you need to incorporate a body force (momentum source term) for modeling the capillary effect. This would come from some empirical relation (based on wick properties).
July 13, 2019, 12:16 |
Amod Kumar
Rep Power: 16 |
Did you solve the problem? I think you need to activate surface tension and wall adhesion to activate capillary effect.
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Heat Transfer in a pipe flow(hot air) | Saima | Main CFD Forum | 0 | January 17, 2011 07:08 |
FEA Simulation of heat pipe | bensonnggl | ANSYS | 0 | September 25, 2010 00:59 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
