Home > Forums > General Forums > CFD Freelancers
FAN 3D geometry and meshing for ANSYS FLUENT
Old   April 15, 2019, 08:19
Default FAN 3D geometry and meshing for ANSYS FLUENT
jose_1953 is on a distinguished road
Good morning,
In the past, for this kind of simulation I used Gambit without problems.
- Geometry:1-> Volume, wing volume and propeller disk surface as FAN definition.
2-> Subtract Volume and wing volume to create fluid volume domain.
3 -> Split the fluid volume domain with propeller disk surface. That's all.
4 -> Meshing.
5 -> Fluent and boundary condition definition as FAN
Could you be so kind to explain how to proceed with ANSYS workbench XX.Y
Thank you in advance
jose_1953 is offline   Reply With Quote
Old   April 22, 2019, 13:45
DOP
Panov Dmitrii
DOP is on a distinguished road
Hi
I think the best option is use icem cfd.
DOP is offline   Reply With Quote
Old   May 4, 2019, 11:09
Burhan Ibrar
burhanibrar is on a distinguished road
Originally Posted by jose_1953 View Post
Good morning,
4 -> Meshing.
Hello Dear,
If you are looking for a freelancer to do this project then contact me i have the expertise for this project. thank you
burhanibrar is offline   Reply With Quote
Old   May 9, 2019, 00:18
Huynh Phong Thanh
hiuluom is on a distinguished road
Good morning,
4 -> Meshing.
If you need help, you can post in other section forum. But in this freelancer, you are looking for a freelancer to do this project then contact me via email fluidtool@gmail.com. I have the experience for this project. thank you
hiuluom is offline   Reply With Quote
Old   May 10, 2019, 12:52
PEC
PEC
PEC is on a distinguished road
Hai, My name is Paramesh. I have worked on a similar project.
You can call me at 8074810789
Or write to me at paramesh@tamminainfotech.com
thank you
PEC is offline   Reply With Quote
Old   July 25, 2019, 15:15
Smile Fan Analysis
ShrivshreeTech
ShivshreeTech is on a distinguished road
I have experience on similar type of fan projects
Contact me info@shivshreetech.com, suryawanshirh777@gmail.com
ShivshreeTech is offline   Reply With Quote
ansys 14, desingmodeler, fan bc, gambit 2.4.6, mesh 3d
Cannot import Geometry into Fluent Meshing 2019 R1 edward.pocock FLUENT 2 January 15, 2024 04:33
[ANSYS Meshing] polyhedral mesh which is generated directly in Workbench Poly Meshing for Fluent teguhtf ANSYS Meshing & Geometry 0 January 24, 2019 22:04
[ANSYS Meshing] CATIA Geometry Generation and Meshing danielsullivan ANSYS Meshing & Geometry 0 April 3, 2017 21:11
[DesignModeler] Importing Solid Edge ST4 Geometry into Ansys Fluent 13.0 for meshing The Mighty Rearranger ANSYS Meshing & Geometry 0 November 27, 2012 12:44
[ICEM] Meshing adjacent wall geometry and simple ICEM questions everdimension ANSYS Meshing & Geometry 25 June 20, 2012 04:25
