April 15, 2019, 08:19 |
FAN 3D geometry and meshing for ANSYS FLUENT
Good morning,
In the past, for this kind of simulation I used Gambit without problems. - Geometry:1-> Volume, wing volume and propeller disk surface as FAN definition. 2-> Subtract Volume and wing volume to create fluid volume domain. 3 -> Split the fluid volume domain with propeller disk surface. That's all. 4 -> Meshing. 5 -> Fluent and boundary condition definition as FAN Could you be so kind to explain how to proceed with ANSYS workbench XX.Y Thank you in advance |
April 22, 2019, 13:45 |
Panov Dmitrii
Hi
I think the best option is use icem cfd. |
May 4, 2019, 11:09 |
#3 | |
Burhan Ibrar
Rep Power: 7 |
Hello Dear, If you are looking for a freelancer to do this project then contact me i have the expertise for this project. thank you |
May 9, 2019, 00:18 |
#4 | |
Huynh Phong Thanh
Rep Power: 12 |
May 10, 2019, 12:52 |
PEC
Rep Power: 7 |
Hai, My name is Paramesh. I have worked on a similar project.
You can call me at 8074810789 Or write to me at paramesh@tamminainfotech.com thank you |
July 25, 2019, 15:15 |
Fan Analysis
ShrivshreeTech
Rep Power: 6 |
I have experience on similar type of fan projects
Contact me info@shivshreetech.com, suryawanshirh777@gmail.com |
ansys 14, desingmodeler, fan bc, gambit 2.4.6, mesh 3d |
Cannot import Geometry into Fluent Meshing 2019 R1 | edward.pocock | FLUENT | 2 | January 15, 2024 04:33 |
[ANSYS Meshing] polyhedral mesh which is generated directly in Workbench Poly Meshing for Fluent | teguhtf | ANSYS Meshing & Geometry | 0 | January 24, 2019 22:04 |
[ANSYS Meshing] CATIA Geometry Generation and Meshing | danielsullivan | ANSYS Meshing & Geometry | 0 | April 3, 2017 21:11 |
[DesignModeler] Importing Solid Edge ST4 Geometry into Ansys Fluent 13.0 for meshing | The Mighty Rearranger | ANSYS Meshing & Geometry | 0 | November 27, 2012 12:44 |
[ICEM] Meshing adjacent wall geometry and simple ICEM questions | everdimension | ANSYS Meshing & Geometry | 25 | June 20, 2012 04:25 |
