Home > Forums > General Forums > CFD Freelancers
2D pipe flow analsys problem
Like Tree1Likes
  • 1 Post By Gert-Jan
Old   March 5, 2023, 12:41
Default 2D pipe flow analsys problem
BLnTCLK is on a distinguished road
Dear friends,
I am trying to analsys in 2D pipe flow.
But as you can see at picture. The flow is dispersing in pipe certain location.
I could not understand, why did happen this. I attached a jpeg file.
Could you please help me?
Thanks in advance,
Regards,
BLnTCLK is offline   Reply With Quote
Old   March 6, 2023, 19:06
Gert-Jan
Gert-Jan will become famous soon enough
Look in open literature on flow on a sudden expansion as analysed by e.q. Dellenback.
evcelica likes this.
Gert-Jan is offline   Reply With Quote
Old   April 5, 2023, 14:20
Default For outsourcing
Ali Riaz
ALI Riaz is on a distinguished road
Kindly contact at +92-336-8637493 or freelanceengineers007@gmail.com to outsource project, please.
ALI Riaz is offline   Reply With Quote
Old   May 15, 2023, 09:59
Popoff
Mr_Flow is on a distinguished road
Well, first you must know what Reynolds number it is. Because you'll know what regime of your flow. Laminar, transition or turbulent.
There are many other things you must know of fluid mechanics before you start your analysis. I recommend you to read a book. My favorite is 'Introduction to Fluid Mechanics - Fox and McDonald', but is kind of hard. The most understandable book from this theme, in my opinion, is "Fluid Mechanics - Çengel, Cimbala".
Any further questions you can ask me! =D
Mr_Flow is offline   Reply With Quote
Old   May 21, 2023, 02:03
SURIYAGOWTHAM S
suiryagowtham is on a distinguished road
Originally Posted by BLnTCLK View Post
Dear friends,
Thanks in advance,
Regards,
Contact me if any technical support is needed as a freelancer.
WhatsApp : +918778721439
suiryagowtham is offline   Reply With Quote
Old   June 6, 2023, 14:41
Erik
evcelica is on a distinguished road
What you are seeing is a well known flow phenomenon called the "Coanda effect". It is due to the Bernoulli principal where higher velocity = lower static pressure. The jet will become unstable and end up attached to one wall, where it will stay since the velocity is higher, and therefore pressure is lower on that one side.
This is a great example of a perfectly symmetric geometry which results in a non-symmetric flow, showing one must be careful applying symmetry conditions to flow which may not have a symmetric solution.
evcelica is offline   Reply With Quote
triangular pipe flow problem Quest.Qiu OpenFOAM 4 February 1, 2022 01:49
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Multiphase flow in a pipe with a CHT wissal CFX 4 June 12, 2017 12:15
3D Swirl flow in the pipe: convergence problem Sachin U. Nimbalkar FLUENT 5 December 22, 2016 01:34
air flow in pipe with heat problem keng Main CFD Forum 1 March 5, 2010 10:40
