How to set slip velocity and temperature jump
Old   April 24, 2012, 23:40
Default How to set slip velocity and temperature jump
awu
awuunity is on a distinguished road
Hey friends:
I am dealing with microchannel heat transfer in CFX,but i dont know how to set up slip velocity and temperature jump boundary condition . I choose finite slip wall,but i dont know how to set slip modal and wall velocity.I am new to CFX.
Thanks for any possible help.
awuunity is offline   Reply With Quote
Old   April 25, 2012, 07:48
In CFX you can only have no slip walls or specified shear stress. There is no finite slip built in. You will have to derive it yourself and impose it as an expression (hopefully as CEL) on either a no slip wall (with wall motion presumably) or a shear stress wall.
Old   April 25, 2012, 21:19
Default slip velocity
awu
Dear ghorrocks:
Thank you for your help. But I still don't fully understand. How can i use CEL to simulate velocity slip?What should i edit in CEL?That would be the best for you give me a example.
Best regard
awuunity
Like
Old   April 26, 2012, 06:04
You have to know the mathematics of what you want to implement before you can implement anything. What is the mathematics of what you want to apply?
Old   April 26, 2012, 08:05
awu
Dear ghorrocks:
Thank you for your help.I want to simulate water flows through tube and the tube's diameter is 0.01mm, length is 2mm. tube's outer surface temperature is 333.15K.The velocity of inlet set to 0.1m/s,temperature set to 293.15K.Set outlet static pressure to 0Pa.
Best regard
awuunity
Old   April 26, 2012, 18:39
This is all routine stuff, the normal boundaries can handle this. Your first post mentioned a finite slip wall - do you really need this?
Old   April 27, 2012, 22:06
Default 3Q
awu
Dear ghorrocks:
I learned the help documentation of cfx,I think that maybe i should choose to finite slip wall,but i dont know how to set slip speed according to my model.
Best regard
awuunity
Old   April 29, 2012, 06:50
Do you even know what a finite slip wall is?
Old   June 30, 2018, 15:43
Jasmina
Jasmina92 is on a distinguished road
Im also dealing with a slip wall condition in Ansys (18.2).
i need to calculate a viscous non-newtonian fliud flow through a very small conical needle (0.6 mm diam.), and i read that a slip condition is needed to be set for a non-newtonian fluid.
as far as i can say, a "finite slip wall" is appropriate in this case - but for the implementation are some parameters needed, which i never heard before..
in the doc is just the underlying equation listed: pls check out https://www.sharcnet.ca/Software/Ans.../i1301372.html
"2.7.1.3 finite slip wall"
Has anyone an idea how i could figure out the needed parameters? I couldn't even find the real meaning of them..
thank you very much!
Jasmina92 is offline   Reply With Quote
Old   July 1, 2018, 06:37
This is not a commonly used part of CFX so I don't think you will get many users who have used it. I have never used it.
But it seems to be simple enough to me, it is used to model a shear thinning boundary layer. If you want to work out the value of the parameters to use in it then do a simple analytical boundary flow with your non-newtonian model, and fiddle with the model parameters until the model fits the analytical result closely enough you are happy with it. If you want to get serious you can use a non-linear regression to fit the parameters.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   July 2, 2018, 08:40
Jasmina
Thank you for your idea!
I will see if I can find some analytical equations which also consider a slip wall...
Still, I worry about 3-4 parameters to vary to achieve an appropriate result. Maybe I change the constrains so no "slip-stick" would occur (if that works).
Thank you!
slip velocity
Implementation of maxwell slip velocity and Temperature jump with openfoam yassepid OpenFOAM 2 June 28, 2016 07:05
2-d axisymmetric microtube flow with velocity slip and temperature jump b.c. dayashankar FLUENT 1 May 18, 2016 21:45
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
