Rep Power: 17 ![]() |
I have an inlet that resembles a grille ( please look into the attached image) could some one please tell me if it is possible to model it just as a plane inlet but then assign some flow resistance to it in CFX with out actually modeling it as a grille.
Best regards, Santhosh. |
Erik
Rep Power: 23 ![]() |
Normally you would use a porous ddomain and assign the area porosity and loss model to it. If you do this be wary of what you assign for you input flow and whether you choose superficial of true velocity. Also check your results for correct mass flow, as some have reported errors if using a velocity flow rate, meaning the solver doesn't respect the proper superficial/true mass flow rates.
If its right at your inlet, can't you just ignore it and add whatever flow resistance you wanted to add later? |
Pulsating flow with non-reflective inlet boundary | cc1000 | CFX | 6 | April 27, 2009 08:10 |
Problems modeling subsonic engine air inlet with flow separation | TWaung | CFX | 2 | March 29, 2009 18:42 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
Reversed flow in pressure inlet | eric | FLUENT | 3 | January 26, 2004 20:04 |
Inlet diffuser of ramjet | Mohammad Kermani | Main CFD Forum | 25 | December 29, 2000 18:46 |
