How to use values of a plane cutting the domain for inlet conditions? |
June 27, 2012, 02:49 |
Rep Power: 14 |
Dear all,
I have the case that I want to simulate a flow channel containing a combustion chamber in which I want to inject vaporized kerosene. The problem is that my computational ressources are quite limited. By now I have results for my flow channel without injecting anything. As I need a very fine mesh in the injection region (which leads to a big mesh), I want to cut my flow channel by a plane upstream the injection point and use these results from this plane as my inlet conditions for my case with injection and then just calculating this part. By now I have no idea how I could manage this. Any help and suggestions are highly appreciated! Best regards, Stefan |
June 27, 2012, 07:39 |
Rep Power: 143 |
Have a look at the profile boundary condition option.
June 27, 2012, 09:05 |
Rep Power: 14 |
Thanks for your hint, Glenn. This is exactly what I was looking for.
But now I have problems Importing it. I performed the following steps: First I created a plane in ANSYS CFX Post. Then I exported the data on this plane to a BC Profile. Afterwards I started CFX Pre and wanted to Import it, but it crashes everytime. I exported data for all variables except of that for heat flux. Any idea what could be the reason? |
June 27, 2012, 09:22 |
Peter Galimutti
Rep Power: 14 |
in the cfd post go to file--> export--> velocity & other variables required at the plane.
you should be able to get a .csv file with physical co-ordinates and their corresponding variable values. i don't remember importing, but i'll post the rest after i get accesss to CFX. but if this is what you have done ignore it! |
June 27, 2012, 09:26 |
Rep Power: 14 |
Dear Peter,
this is exactly what I did, but I want to export values for all variables. So I chose costum export and not total pressure or velocity option for export as with this options it is only possible to export a part of the variables. But with this custom option CFX Pre crashes when I want to import my file. When I choose total pressure option instead it works fine, but as I wrote I would like to have tha values for all variables. |
June 27, 2012, 09:39 |
Peter Galimutti
Rep Power: 14 |
you just need velocity or pressure and thermal bcs for initialization.
if it crashes it may be due to systems limited resources as you mentioned earlier. Probably what you can do is give initial condition in 'Initial value specification' in the 'Solver Manager'. All you need to do is use the previous result file. however it may warn you that the initial mesh is not matching the new mesh, but it's alright, the values get interpolated. HTH Last edited by p.galimutti; June 27, 2012 at 12:00. |
June 28, 2012, 03:56 |
Rep Power: 14 |
As Inlet I want to use a total pressure bc, but if I just export and import the pressure and velocity values I will loose the turbulence, right?
June 28, 2012, 09:29 |
Peter Galimutti
Rep Power: 14 |
then try the last step in my previous post. it will initialize all the data! it's pretty easy...this is the screenshot of how you can use previous results using solver manager
July 2, 2012, 04:08 |
#9 |
Rep Power: 14 |
But the problem is, that in the combustion chamber the flow is completely subsonic, but if I interpolate the results from the whole flow channel, also the supersonic region in the flow channel will be taken into account, right?
July 3, 2012, 08:05 |
#10 |
Rep Power: 14 |
Another question:
I have the problem that my y coordinate in the case from which I want to export the values of the plane differs from these I want to import them as my inlet boundary condition. Is it possible to make a coordinate transformation when I want to import the values? |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
Symmetry Plane boundary conditions | Tudor Miron | CFX | 1 | March 17, 2004 00:12 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 18:29 |
