HI need import .gtm file to Fluent or Gambit? |
December 8, 2010, 13:27 |
mirion
Rep Power: 15 |
Hi I have a problem we got some results from CFX code and company sent us grid but is in .gtm format. I am not familiar with CFX and need import this to Fluent or Gambit is any chance to do that or must be a new file with different extension? I am putting this post here because you guys are expert in CFX.
Many Thanks Rob |
December 8, 2010, 16:56 |
Edmund Singer P.E.
Rep Power: 20 |
I am not a fluent user, so I have no idea if ANSYS gave it the capability to import gtm files. But if you have the CFX def/res file you can pull that into icem and output into what format you need. Also you could use FE modeler to do the same thing.
December 8, 2010, 17:09 |
Rep Power: 143 |
You can also do file translations easily in WB. Set up a project with a CFX node and a Fluent node. Import the gtm file into the CFX node and connect the setup to the fluent node. Then, by some sort of magic, you will have your mesh in fluent.
December 8, 2010, 17:12 |
Edmund Singer P.E.
Rep Power: 20 |
Too bad we cant use that same sort of magic to place a DM node and a Mesh node...voila!
December 8, 2010, 19:09 |
mirion
Rep Power: 15 |
December 8, 2010, 19:13 |
mirion
Rep Power: 15 |
Hmm any chance to get working CFX ? or different somebody can translate this file for me from gtm to gambit/fluent ?
December 8, 2010, 19:54 |
Rep Power: 143 |
WB = Workbench
July 3, 2012, 16:23 |
#8 | |
Ghazlani M. Ali
Rep Power: 28 |
This transfer is not valid. Expected mesh type |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
how can i import igs file in gambit? | Javier | FLUENT | 2 | May 23, 2011 10:51 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
