July 13, 2012, 10:22 |
CFX problem in ubuntu (linux)
Vigneshram
Rep Power: 15 |
p, li { white-space: pre-wrap; } ccl validation error..... how to remove or overcome this error anybody have any solution....... pls and thank you
the error i got is : ERROR CCL validation failed with message: Warning: Can't check object /DEFAULT RENDERING: Can't find rule. Skipping object and all children. Error: Parameter 'Limit Marker Vertex Count' is not allowed in /LABEL CONTROL Error: Parameter 'Number of Markers' is not allowed in /LABEL CONTROL Error: Parameter 'Vertex Threshold' is not allowed in /LABEL CONTROL Warning: Can't check parameter Message (/PHYSICS MESSAGES/PHYSICS MESSAGE:msg0000/Message): Can't find rule. Warning: Can't check parameter Message Type (/PHYSICS MESSAGES/PHYSICS MESSAGE:msg0000/Message Type): Can't find rule. Warning: Can't check parameter Severity (/PHYSICS MESSAGES/PHYSICS MESSAGE:msg0000/Severity): Can't find rule. Warning: Can't check parameter Suppressed (/PHYSICS MESSAGES/PHYSICS MESSAGE:msg0000/Suppressed): Can't find rule. Error: Parameter 'Strict Domain Type Checking for Automatic Interfaces' is not allowed in /PHYSICS OPTIONS CONTROL Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:BLD HIGH: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:BLD HIGH 2: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:BLD LOW: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:BLD LOW 2: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:HUB INBlock: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:HUB Passage: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:HUB Passage 2: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:INFLOW INBlock: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:INFLOW Passage: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:INFLOW Passage 2: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:OUTFLOW INBlock: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:OUTFLOW Passage: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:OUTFLOW Passage 2: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:PER1 1 Passage: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:PER1 2 INBlock: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:PER1 2 Passage: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:PER1 Passage: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:PER2 1 Passage: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:PER2 2 INBlock: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:PER2 2 Passage: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:PER2 Passage: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:SHROUD INBlock: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:SHROUD Passage: Can't find Allowed Option List. Warning: Validation aborted for Option 'Default Rendering' in /PRIMITIVE2D:SHROUD Passage 2: Can't find Allowed Option List. Error: Parameter 'View Length Units' is not allowed in /VIEWPORT MANAGER Error: Parameter 'Viewer Eye Point' is not allowed in /VIEWPORT MANAGER Error: Parameter 'Viewer Eye Separation' is not allowed in /VIEWPORT MANAGER |
Ansys 13 - License problem on Ubuntu | MarTar | ANSYS | 4 | February 3, 2012 02:13 |
CFX 13 Linux (Ubuntu 11.10) local parallel setup | TSokl | ANSYS | 0 | January 16, 2012 07:35 |
Numerical oscillations in CFX with water boiling problem. | michujo | CFX | 4 | December 16, 2011 09:00 |
Moving Mesh Run problem - Scientific Linux | G. SE | Siemens | 2 | May 7, 2008 07:15 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
