August 5, 2012, 00:43 |
vertical flat plate/plate normal to flow
Hamed Abdul Majeed
Rep Power: 13 |
I need to validate the results of a vertical flat plate or plate normal to flow in CFX. Can any body recommend/share any research paper/previous work in this regards. The flow should be incompressible, steady, and turbulent. Thank you Regards Hamed |
August 5, 2012, 14:22 |
Hamed Abdul Majeed
Rep Power: 13 |
Anybody having any knowledge plz reply!
August 5, 2012, 19:23 |
Rep Power: 143 |
I doubt you will find many CFD studies of this precise flow as it is not very exciting. The drag has little to do with complex physics, the bernoulli equation explains it pretty well.
Flow Direction: normal to boundary!!! | Atit | CFX | 1 | August 2, 2015 13:42 |
problems for the flow over flat wall | iilw1314 | Main CFD Forum | 0 | March 19, 2010 04:53 |
Flow over a flat plate & Flow over a cylinder | cfdxue | Main CFD Forum | 0 | November 26, 2007 23:26 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
Seperated Flow and Turbulence modelling flat plate | Simon Mizzi | Main CFD Forum | 1 | December 16, 2003 01:26 |
