August 30, 2012, 17:18 |
I can't plot a velocity distribution
Hello. I'm sorry if i don't speak english very well, but I'll try my best to make you understand my problem. I need to plot the distribution of the circumferential velocity all the way around the outlet border of this nozzle (not exactly at the wall, just a little bit far from the nozzle wall). I've created a polyline using the "file" option (inside this file I stored the coordinates of 60 points through which the polyline passes) -maybe you can see it painted in green- and now I have to plot this velocity component vs the variable "Gamma Var" defined as follows: Expressions -> New Expression -> Gamma Expr -> atan(y/x) Variables -> New Variable -> Gamma Var -> Details of Gamma Var -> Expression -> Gamma Expr. Then I've created a new Chart, I've selected a new data serie indicating the polyline already created. Then in the X tab I've selected "Gamma Var" as my X variable and "Velocity Circumeferential" as my Y variable. Nothing happens apart the warning: 'No data exists for variable "Gamma Var" specified in object "chart Line 1'. Where do I committ my mistake??? Please please help me... P.S: X axis is parallel but not coincident with the nozzle's symmetrical axis. The inlet and outlet planes are parallel to YZ planes |
September 3, 2012, 18:56 |
Erik
Rep Power: 23 |
I can't see the green line well, but is it inside your models bounds?
September 4, 2012, 21:51 |
Erik
Rep Power: 23 |
looking again you have atan(y/x), should this be (y/z?)
Time-averaged velocity plot for a transient simulation | mali28 | FLUENT | 21 | September 24, 2019 22:34 |
how to apply circumferential velocity distribution | pks126 | Main CFD Forum | 0 | August 20, 2012 13:00 |
velocity profile plot | girishg | Main CFD Forum | 0 | February 24, 2011 18:11 |
how to plot RMS velocity (fluctuating velocity) | nash | Main CFD Forum | 0 | October 18, 2006 16:37 |
