CFX solver workspace & ourfile Problem
Old   October 16, 2012, 11:36
Default CFX solver workspace & ourfile Problem
yang
wangy1767 is on a distinguished road
Dear all,
I run a CFD simulation, but after 20 steps CFX solver workspace & ourfile can not continue to show simulation-running-situation, but I'm sure it is running. Since the new *.TRN files still can be produced in .dir file.
Please tell me how to let CFX solver workspace & ourfile can not continue to show simulation-running-situation continuously?
I already tried to use File/Monitor run in process to run this CFD simulation in a new CFX solver, but it still shows the old one until 20 steps not the current step.
Many thanks in advance!
wangy1767 is offline   Reply With Quote
Old   January 9, 2013, 09:38
Wink How to Get Solver manager back on line / Monitor a run in progress.
jrl4444 is on a distinguished road
I Hope this information will save a few runs from getting Trashed / Crashed.
Oh yes a RED X window corner close without stopping the run, no big deal if you know what to do.
Open a new Solver Manager ..... Go to the File menu .... Click on
MONITOR RUN IN PROGRESS
Find the folder with the .dir ..... If you sort by date it is much easier to find.
High light/single click the folder do not go into the folder just high light the folder and click the open button.
Confusing because you might think you need to open some file but not so you are opening the folder. It will pop up with nothing lost and at the end of run it will do all the .mon file merging.
Strange thing I had happen once is after a few runs 001 002 003 ect.... I went in to the drive and cleaned up / deleted all the earlier completed runs, folders, .res, and .out files so my next run would start on 001. I started the run everything seemed fine, later as I was closing some windows I discovered what I thought was 2 runs going at once. Nop I still had a 001, same file name Manager window open from an earlier run that I had deleted. After clean up I had stated another 001 run and turns out I ended up with 2 manager monitoring the same run.
No big deal I just closed one manager {RED X corner close} NOT A STOP, left other one running and it completed perfectly normal.
Have a great day all!!
Last edited by jrl4444; January 9, 2013 at 09:39. Reason: Removed double line spacing
jrl4444 is offline   Reply With Quote
mesh.update problem in a new FSI solver ICL OpenFOAM 0 October 8, 2011 14:16
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
ERROR #002100056 CFX FSI problem Hongdao CFX 0 November 10, 2010 03:58
CFX new user, problem with solver and PRE settings Vijesh Joshi CFX 1 March 13, 2006 22:42
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
