October 30, 2012, 20:10 |
Problem with instalation Ansys CFX 12.1
Talles Caio
Rep Power: 13 |
Personnel in the resettlement ansys 12.1 64 bit, the following error occurred: unexpected error: The type initializer threw an exception ans.core.units.unitsmanager, someone knows what could be? sitema my OS is win 7 64-bit basic, unas already tried to install 3 times but it installs naum opens and informs this error?
October 31, 2012, 12:14 |
Erik
Rep Power: 23 |
This error occurs when the ANSYS environment variables are set incorrectly. For example: the ANSYS installation directory is C:/Program Files/ANSYS Inc, but AWP_ROOT120 is set to D:Program Files/ANSYS Inc/v120. Changing the incorrect environment variable setting to the correct path will resolve the problem.
What drive are you installing it to? |
October 31, 2012, 20:02 |
Talles Caio
Rep Power: 13 |
installed the following path c / program file / ansys Inc/v120. the directory c: is the only existing on my computer!
November 1, 2012, 21:20 |
Talles Caio
Rep Power: 13 |
Hello, I checked all the environment Variables are correct, you would know another possible cause of this problem?
thanks for your help! |
November 2, 2012, 05:16 |
Erik
Rep Power: 23 |
Sorry, No other ideas here, It has always installed fine for me. Perhaps something in your ANSYS installation file is corrupted?
November 2, 2012, 07:57 |
Talles Caio
Rep Power: 13 |
is a possibility, but I tried to install two different programs ansys 12.1 64 bit and the same error was made, is a curiosity that had installed another time and it worked, but he had some problems the CFX-Mesh was not opening, so decide uninstall and reinstall there was when the error occurred.
anyway thanks for your help! |
Problem with modelling contact in ansys fluent 12.1 | mak86 | FLUENT | 16 | August 27, 2019 09:07 |
CFX Casting problem: Can it be done all in one? | jfasl | CFX | 1 | September 14, 2010 03:14 |
2D suction in ANSYS CFX 12.1 | Apostolis | CFX | 1 | June 3, 2010 08:01 |
Problem on mesh import to Ansys CFX 10.0 | Stephen Lau | CFX | 1 | April 18, 2007 03:02 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
