October 30, 2012, 05:17 |
chart problem please help
jayanth joseph
Rep Power: 13 |
hi guys i just did a aerodynamic analysis using cfx
i used inlet velocity as 16 m/s i have obtained results such as drag and lift force, coefficent using suitable expressions. in the post processor CFD POST i just want a plot of the drag,lift forces vs velocity and drag and lift coefficients vs velocity when i try to do this im asked for a data series i create a line like the ones that are given in the tutorial but still i am unable to choose these variables which i have defined as they do not appear in variable drop down list boX When i check in the conservative variable box another large list of variables appears but the ones i have defined are not to be found another doubt is that it says Forces can be calculated only in planar areas , so can i give a plane as a data series please do help me out im relatively new to cfx and i need the graph for a report which has to submitted as quick as possible thank you |
October 31, 2012, 11:38 |
Erik
Rep Power: 23 |
You have created expressions, but have you created variables from the expressions? that may help.
I don't think you can specify a plane as a data series. But if you think about it, of course a force has to be integrated over an area, but you can normalize it and plot pressure along your line instead of force (pressure = force per unit area) What is the Velocity you are plotting against? I see you are running only 1 simulation. |
chart count, drag, expressions, problem, variable properties |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 08:39 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Problem in CFX5POST Chart function. | windhair | CFX | 2 | September 20, 2004 07:49 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
