November 16, 2012, 10:40 |
Simulating Heat Transfer
Felix
Rep Power: 13 |
Hi everybody,
I'm new to this forum and I hope you can help me. Concerning my thesis i have got to simulate convective heat transfer inside an autoclave as well as the heat transfer on a Tool placed inside the autoclave. I am still learning to use ANSYS CFX at the moment. So I want to do some simple test simulations about convective heat transfer from fluid to a solid square inside a duct. I want to simulate the heating of the square from an initial temperature of 300 K, while to sourrounding fluid has a temperature of 1000 K. The fluid domain is meshed with tetrahedrons and inflation layers near the square. The Solid is meshed with a structured mesh. The fluid is air at 25°C, Reference pressure 1 atm, Turbulence Model SST, while the square is of aluminium. I have set both, fluid and solid Heat Transfer to Thermal energy. I have set a domain Interface between solid and fluid and have set heat transfer to conservative interface flux with a contact resistance of 120 W/mēK. The condition at the inlet of the duct are 3 m/s Normal Speed and a temperature of 1000 K. Outlet is Relative Pressure 0 Pa. First i did a steady state simulation with the above parameters and afterwards a transient simulation with initial values from the steady state simulation. The timesteps are 2 min and total time is 30 min. My first results do not seem to be correct. The steady state simulation shows a uniform temperature profile in the square AND the fluid of 1000K. The transient simulation doenst change over time and has the same temperature profile in every timestep. Acutally I am expecting a time dependent heating of the square. 1. Do i have to set the temperature at the inlet to 1000 or 300 K in the steady state simulation? 2. Do I have to choose smaller timesteps? 3. What am I doing wrong? Hope you get my problem. If not, please ask me. Thanks for help. Greetings. |
November 17, 2012, 02:09 |
Rep Power: 14 |
I suppose you have to use coupled boundary condition between for Fluid sloid interface. It is taken by default even if u dont define any interface and flux conservation is satisfied there. Inlet at 1000k in Fluid domain is fine, Initialize solid domain with 300 K.
November 17, 2012, 19:09 |
#3 | ||
Rep Power: 143 |
Why do you have a contact resistance between solid and fluid domains? What does this represent?
Here is the general FAQ on accuracy: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F |
November 19, 2012, 11:08 |
Felix
Rep Power: 13 |
Thank you for answering.
The problem was that there has been a uniform temperature profile in transient simulation. I did the setup without contact resistance and just a transient simulation now. This gives better results now. Do I have to adjust the solid and the fluid mesh for a better result(Contact Sizing)? |
November 19, 2012, 16:52 |
#5 | ||
Rep Power: 143 |
heat transfer, temperature profile, transient |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
Heat Transfer in Porous Medium | eryan | STAR-CD | 0 | September 28, 2010 13:14 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
Question on heat transfer coefficient!!! | Benny | FLUENT | 7 | June 7, 2005 09:25 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
