CFX Boundary Conditions Will Not Decouple
Old   December 11, 2012, 15:41
Default CFX Boundary Conditions Will Not Decouple
Samuel J. Hund
samuelhund is on a distinguished road
I'm using Ansys Workbench to design a axial flow pump. I have coupled blade gen to turbogrid to cfx in the workbench. I open the CFX setup cell (which launches CFZ-Pre). When I go to the Default Domain: Default Domain Default where it allows me to change the boundary conditions in the Boundary: Default Domain Default tab. The default value for all boundaries is Wall. I select inflow passage and change that to inlet. However, every thing else likewise becomes an inlet. I've fixed this problem once before, but I cannot remember how. Can any one help?
samuelhund is offline   Reply With Quote
Old   December 11, 2012, 16:01
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
You can delete your "Default Domain" boundary condition and start over defining the boundaries you actually want individually.
Alternatively, under "Case Options" -> "General" you can turn off "Automatic Default Domain". Problem is, if you are using Workbench, the mesh is already loaded when Pre is launched. Therefore, I would try opening CFX-Pre separately first and setting this as default for the next time it is launched through Workbench.
I think this will fix the problem you are having. First option is easiest, but second option is useful if you have many similar cases where this could be an issue.
cdegroot is offline   Reply With Quote
boundary conditions, cfx, cfx-pre
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
ribbed channel / simpleFoam / boundary conditions beeo OpenFOAM Pre-Processing 20 July 17, 2013 08:39
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
