December 31, 2012, 12:09 |
Volume patch
Prateek
Rep Power: 14 |
I have one doubt, I wish smeone can help on this.
As i told you am trying to model detonation and I am done with mixing of tube with fluid, now I want to use these results (.res) as input file for next step i.e. ignition. For ignition I am using a small volume patched with high temperature and pressure (5 atm and 2000K )and another bigger volume i.e rest of the tube with 300K and 1 atm. but the problem is after i start the run i saw that volume is not patched with HIGH temp and pressure (as I check at 0 time step). I am thinking that its taking the value of temperature and pressure from results file, but then in that case How can i patch this domain?? What could be the possible reason?? |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
UDF for ellipse shape volume patch in VOF model | nazeem | FLUENT | 1 | October 8, 2004 11:22 |
