ducted fan setup. help me!
Old   May 9, 2013, 04:10
Default ducted fan setup. help me!
yang
kr2552 is on a distinguished road
First of all i am sorry that i'm not good at english
i made two geometry (stator, rotor) then i used turbo grid and made meshes
in cfx setup i use frozen rotor and ratio 1
but in result looks like discconection between rotor and stator
i check it by stream line
in rotor stream line moving rotational direction but in stator in just go down not affected by rotor
how can i solve it....... can u explain easily? i tried to read tutorial but i can not find proper example
kr2552 is offline   Reply With Quote
Old   May 9, 2013, 04:34
hmasenger's Avatar
hamed
hmasenger is on a distinguished road
Did you well defined connection constraint before meshing the domains? Take a look at that you need a connection mesh sizing
hmasenger is offline   Reply With Quote
Old   May 9, 2013, 06:25
Can you post an image or what you are seeing?
Also, are you drawing streamlines using Velocity or Velocity in Stationary Frame?
Fluent setup to determine fan performance afaik FLUENT 5 August 1, 2014 04:27
[Pointwise] cannot set "fan" boundary condition to 2D Ducted fan model brksnn Pointwise & Gridgen 1 January 11, 2013 09:05
Flow recirculation around a ducted fan Jane Main CFD Forum 2 January 24, 2012 05:17
Question about flow in ducted fan in another duct Jane FLUENT 0 June 21, 2004 13:57
axial flow in counter rotating ducted fan Vishu FLUENT 4 January 13, 2004 17:52
