Difference vectors of two simulated configurations!
Old   January 22, 2013, 07:58
Default Difference vectors of two simulated configurations!
powpow is on a distinguished road
I simulated two different configurations of a test chamber (shown in the images).
At CFD-Post I have displayed the velocity vectors.
My question: Is it able, to load both results into one file and show the "difference vectors"?
I want to show how the vectors have changed because of the other configuration.
Thanks a lot!
powpow is offline   Reply With Quote
Old   January 22, 2013, 11:14
Lance
Lance is on a distinguished road
You can use the case comparison feature in cfd-post to load to .res-files to compare different results.
There's even a tutorial on it, see cfx_tutr.pdf
Lance is offline   Reply With Quote
Old   January 22, 2013, 11:22
Thanks a lot
I'll try it!
Old   January 23, 2013, 07:37
Which tutorial do you mean?
Old   January 23, 2013, 08:27
Lance
load the first results file
then load the second file but select "keep current cases loaded"
select case comparison
I think it is in the end of tutorial 32.
Old   January 23, 2013, 10:09
Thanks a lot! It has worked
I got the velocity difference vectors in an Image.
Is it also possible to get displayed their magnitude?
Periodic Boundary Condition for upwind difference yohey44 Main CFD Forum 0 October 27, 2010 13:10
Integration Points and normal area vectors Bloshchitsyn Vladimir CFX 0 November 26, 2007 07:35
2 velocity vectors ashish CFX 3 June 19, 2007 18:32
velocity vectors same in absolute frame and rel? sam FLUENT 0 March 6, 2007 05:17
What is the difference between these three time ztdep OpenFOAM Running, Solving & CFD 0 September 15, 2005 11:26
