Transient analysis time step
Old   February 25, 2013, 03:12
Default Transient analysis time step
Govindaraju
kmgraju is on a distinguished road
Dear all
I would like to clarify the time steps.
I have a sinusoidal function and the frequency is 1 Hz. I did the transient simulation for one cycle
one of my friends told me and insist me to do the multiple cycle simulations.Is it necessary to do the simulations for multiple cycles?. If I do the multiple cycles the solution time is too large. Is there any way to short cut.
Thank you
Regards
kmgraju is offline   Reply With Quote
Old   February 25, 2013, 04:15
If you want the startup transient then you do not need to do multiple cycles. If you want the repeating cycle it depends how long it settles to a repeating pattern. It could be 1 cycle, it could be hundreds - it depends on how stable the system is and how long it takes to settle.
But you will need to run it long enough to show that you have run long enough - so the change in the last few cycles is small enough that you can call it converged.
Old   February 25, 2013, 05:55
Lance
Lance is on a distinguished road
Glenn is (as always) correct, you will need to perform a sensitivity analysis on the number of cycles in order to avoid initial effects - otherwise the initial conditions will affect your solution.
Lance is offline   Reply With Quote
Old   March 2, 2013, 20:01
Govindaraju
Dear all
I have a set of data from 0 s to 2 s. I used one dimensional interpolation and activated extended minimum and maximum.
My question is
How to run this simulation for repeated cycles.( at least for 4 cycles) ?
Thank you
Regards
Govind
Old   March 3, 2013, 05:19
The simple nasty approach is just to repeat the 1D function 4 times.
The better approach is to use the mod function, so the time input to the interpolation is t-mod(t,2) which should return a function which increase to 2, then goes to zero and increases to 2 again when t is 4, and repeats that forever.
Old   March 3, 2013, 13:14
Govindaraju
Dear Mr Glenn
Thank you . It works
Govind
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 03:41
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
Choosing the apt time step size for a transient run saisanthoshm88 CFX 1 March 31, 2012 16:11
Time step for wind turbine analysis amoolraina FLUENT 4 March 25, 2011 02:58
