February 28, 2013, 04:23 |
Interface model for a radial inflow turbine
KJ
I am trying to simulate a turboexpander with radial inflow and axial outflow. It consists of three parts basically 1. Nozzle : Stationary part, radial flow of fluid 2. Blade : Rotating with high rpm, radial inflow, axial outflow 3. Diffuser : Stationary, along the axis of rotation as shown in the figure. I created all the blades as single blade was not giving me proper results I am using 3 interfaces 1. Rotational periodic betwen the blades Per1 - Per2 2. Frozen rotor, for both the other interfaces. Am I using the correct interface model? Which is the best turbulence model to be used in this. Thanks a lot for helping Please see the link for the system http://dl.dropbox.com/u/11526528/cfx.png |
February 28, 2013, 05:41 |
Rep Power: 143 |
Have a look at the rotating machinery tutorials and documentation about the differences between the different approaches.
The choice of what turbulence model depends on what you are tryign to model as well. In general SST is a good choice, but some applications require RSM, LES, DES or laminar models. |
February 28, 2013, 13:00 |
hitesh
what boundary conditions and cell zone conditions r u using?
cfx, frozen rotor, interface model |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
gas turbine combustor model - HELP! | Phil | Main CFD Forum | 5 | April 10, 2007 11:54 |
gas turbine combustor model - HELP! | Phil | Main CFD Forum | 0 | April 8, 2007 20:38 |
