Question about outlet boundary condtion settting for transitional model |
March 3, 2013, 13:45 |
Meimei Wang
Rep Power: 15 |
When I use the transitional model (Gamma Theta Model), I need to set up the turbulence intensity at the outlet boundary conditions. I'm confused about how do I know it before I simulate it? Thanks!
Best regards, Meimei |
March 3, 2013, 16:55 |
Rep Power: 143 |
You do not specify the turb intensity at outlets. Obviously the turbulence just exits the domain and plays no role in the simulation. Why do you want to specify the turbulence at the outlet?
If you change the outlet to an opening, this will allow back flow and then you will need to specify the conditions of the back flow fluid including turbulence intensity. |
March 3, 2013, 18:35 |
#3 | |
Meimei Wang
Rep Power: 15 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 17:15 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
Question about the outlet boundary condition. | G.H.Lee | Main CFD Forum | 5 | April 29, 1999 04:50 |
