Methane/Air Combustion
Like Tree2Likes
  • 1 Post By ghorrocks
Old   March 16, 2013, 18:21
Default Methane/Air Combustion
Przemek
Batis is on a distinguished road
Hi All,
I would like to ask you guys for an advice in Methane/Air combustion modeling.
Problem description:
Enclosed domain through which air is flowing in a steady state manner (i.e. one inlet & one outlet), additionally one inlet with Methane supply. As a result (steady state) we have formed cloud of Methane/Air mixture with different equivalence ratios in different points in space.
Now I would like to place an ignition source (e.g. energy source) in a region where mixture is flemmable and burn it. I don't won't to simulate a diffusive burner but a sudden ignition of formed mixture. As a result I would like to get an estimated value of temperature/pressure rise in the domain.
The question is: should I consider abovementioned phenomenon as a partially-premixed flame regime? And which out of CFX14 combustion models will be appropriate for such flame model?
Thanks in advance,
Przemek
Batis is offline   Reply With Quote
Old   March 17, 2013, 04:37
I am no expert on combustion modelling so cannot give specific advice. But I suspect if all you want is a pressure/temperature history then a simple model like eddy dissipation will probably be OK. If you want combustion products/exhaust composition then you will need to be more advanced.
amin_jalalian likes this.
Old   March 18, 2013, 15:30
Przemek
Thanks Glenn,
I'll try with EDM.
Regards,
Przemek
Old   March 19, 2013, 04:33
That's the place to start. Only go to the more complex models if you can show the simple ones are not good enough.
Batis likes this.
cfx14, combustion
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
Partially Premixed Combustion - Direct Fired Boiler oknus FLUENT 0 April 10, 2012 10:52
hydrocarbon gases + Boron particle combustion nileshjrane OpenFOAM 1 December 13, 2010 06:20
Hydrogen Air combustion in a combustion chamber popi CFX 7 July 11, 2007 18:40
Need Similar Combustion Tutorial as my model Arnab Siemens 0 May 24, 2005 18:23
