Interface temperature
Old   April 20, 2013, 12:47
Smile Interface temperature
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
hello sir,
in conjugate heat transfer problem i created two separate domains in ICEM CFD
and i have made interface between them in CFX(as shown in attached image)
in solver output monitor plot when i plot AVERAGE temperature of interface surfaces both gives different values
i.e areaAve(T)@inter_fluid and areaAve(T)@inter_solid
i an unable to get why CFX plotting different values
http://s14.postimg.org/ju72t2yi9/Untitled.png
Thank you sir
Suneel patil
sunilpatil is offline   Reply With Quote
Old   April 21, 2013, 07:42
You get different temepratures because it is using the control volumes which have a centroid a small distance off the interface. So you are comparing the temperature a small distance into the fluid domain with the temperature a small distance into the solid domain.
Old   April 21, 2013, 07:49
sunilpatil's Avatar
sunil
Hello sir,
Thank you for your reply,
Sunil patil
interface temperature
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
Is wall ajacent temperature equal to conservative temperature of the wall? shenying0710 CFX 8 January 4, 2013 04:03
Temperature Profile through a fluid solid interface Studentdrak CFX 4 January 31, 2012 22:23
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 17:15
How to force the temperature at the interface equal to the saturation temperature new bubble Fluent UDF and Scheme Programming 0 May 12, 2010 18:06
