Ansys 12 on Windows 8 - Does it work?
Old   April 16, 2013, 10:21
Default Ansys 12 on Windows 8 - Does it work?
rosswell is on a distinguished road
Hello folks,
quick question: has anyone installed Ansys 12 on Windows 8 yet?
If so, is it running well, or are there any issues with Ansys 12 I should know before upgrading my PC to Windows 8?
Thanks!
rosswell is offline   Reply With Quote
Old   April 16, 2013, 10:58
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
ansys 12 works well on windows 7. windows 8 is not that different than windows 7. the shell is the same. it should work
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   April 16, 2013, 14:31
diamondx,
that`s what I also tought. I'm using Ansys 12 on windows 7, but I'm considering the upgrade, so wanted to be sure there will be no compatibility problems.
Thanks anyway!
Old   April 17, 2013, 06:59
Lance
Lance is on a distinguished road
why not consider upgrading to CFX 14.5 while you're at it?
Lance is offline   Reply With Quote
Old   April 17, 2013, 10:22
Lance
By the way, there's a document called "Release 14.5 Windows 8 Known Issues & Limitations" on the ansys customer portal, it might be interesting for you.
Old   April 24, 2013, 09:54
Sorry for the delay and thank you all for your comments.
I've given it a try, and I'm glad to announce Ansys 12 works perfectly well on Windows 8
No issues found so far.
Cheers!
Running Ansys in BAtch Mode kuleuvenstudent ANSYS 1 October 18, 2017 12:11
Fluid structure interaction jnattia Main CFD Forum 25 May 21, 2015 09:16
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation Volker P. ANSYS Meshing & Geometry 22 January 17, 2012 17:27
Ansys workbench problem Jonny6001 ANSYS 2 September 30, 2010 12:59
intel quad core with ANSYS CFX-v11.0 (without SP1) Rogerio Fernandes Brito CFX 12 May 30, 2008 02:59
