May 8, 2013, 12:58 |
paralle meshing
hamed
hi dear frinds
does anyone know how is it possible to run ansys meshing program using 4 prossesors in parallel? i havealready set the number of processores in tools>meshing>number of cpu=4 but i dont see any diffrence in cpu usage in windows taskmanager best regards |
May 8, 2013, 14:06 |
OJ
Rep Power: 20 |
I have read somewhere that multicore meshing is effective only for very large meshes. WHat is your mesh size?
OJ |
May 8, 2013, 16:13 |
hamed
more than 1 milion
May 8, 2013, 22:43 |
Rep Power: 143 |
ICEM can use multiple processors, but only for some parts of the meshing process. But it does help. CFX-Mesh can also do multiple processor but it does it by partitioning the geometry I think and that is a bit harder to set up.
Only a few of the meshing tasks are multi-processor enabled. Most of them still occur single processor. In my experience multi processing in meshing achieves little. Better to get a big machine with enough memory for the entire thing and get let it chug away. It will gt there in the end. A 1 million node mesh is not that big. This should run fine without special multi-processor operation. |
May 9, 2013, 00:22 |
hamed
tnx
by the way do you know how can i define a refinement for some selective elements in domain? Whatever i decrease the sizing element in a surface, there is always some low quality elements with skewness around 1 in it.I don’t know how can i refine this bad elements in the domain as I can’t select them ? Also as i set a face sizing future with sphere of influence it makes lots of elements which i don’t need and also still doesn’t change the maximum skewness factor. I think there is a lake of something like a selection tool in ansys meshing in all versions of this software since ansys workbench 9 !. I don’t know why they don’t do anything about this . can u help me by this? I need a clue regards in advance Last edited by hmasenger; May 9, 2013 at 01:12. |
May 9, 2013, 06:23 |
Rep Power: 143 |
I would try the ANSYS geometry and meshing forum.
May 9, 2013, 06:34 |
hamed
i have already tried that .it seams that cfx forum is more active and people here are more exprienced.but tanks for the advice.
May 9, 2013, 06:40 |
Rep Power: 143 |
I see - but I cannot help you much I fear. All I can recommend is to get familiar with all the meshing options and try them all out. There is no substitute for experience.
And lastly - do not be afraid to subtly modify your geometry to make it easier to mesh. Removing a small misalignment which does not affect the flow and replacing it with a simpler face can make all the difference. |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
