May 6, 2013, 07:22 |
Flow around a cylinder with k-epsilon model
Rep Power: 13 |
I'm trying to simulate a simple flow around the cylinder using CFX. The Reynolds number is 2000, and I use the k-epsilon model as turbulence model. the temperature difference between the cylinder wall and the fluid is 1K. the simulation is running and it also converges but there is no karman vortex Street in this case. But when I simulate the same problem as laminar, then I can see this swirl. the following fotos shows the most important settings for this problem. regards |
May 6, 2013, 07:46 |
Lance
Rep Power: 22 |
Re = 2000 and using turbulence model? I would guess that the turbulence model introduce additional dissipation that removes the vortex street. That would explain why you see the vortex street when you are using a laminar approach.
Why are you using gravity? Is buoyancy important in your flow? |
May 6, 2013, 08:29 |
Mr CFD
Rep Power: 14 |
You have low Reynolds number flow with questionable turbulence. Also it's flow over a cylinder so I assume you have some sort of vortex shedding. I would'nt use k-eps if you were to use a turbulence model. Try k-omega SST, with low turbulence intensity at the boundaries, also try it with and without the gamma-theta transitional model switched on. That transitional model is optimized for low external Re flows.
But before doing that I'd question if it's even turbulent. |
May 7, 2013, 03:59 |
Rep Power: 13 |
hi,
first of all thanks for your tipps. i have increased the raynolds number to 4000, but still no karman street can be observed (see the attachement). i also tried K-omega SST model without considering buoyant effect and obtained the similar results as using K-epsilon model. regards. |
May 7, 2013, 19:41 |
Rep Power: 143 |
You need a low-dissipation numerical model to get the vorticies. Are you using a second order space and time discretisation scheme? And time steps small enough (adaptive timestepping is STRONGLY recommended)?
May 8, 2013, 11:58 |
Irin Sun
Rep Power: 16 |
thank u for your reply.
we used high resolution scheme for this problem. To reduce the additional dissipation caused by turbulence model, now I am going to try CDS for advection scheme, second order backward euler for transient scheme. which scheme will u suggest for turbulence numerics. Should i also use second order since it seems that first order is recommended for turbulence equations. thanks. irinsun |
May 8, 2013, 14:14 |
OJ
Rep Power: 20 |
Are you using scalable wlal funcition? How about using automatic wall function, and using Y+ values of - say close to 1 etc? This will capture the phenomena near wall well and will also work if there are laminar/transition flow structures around your cylinder.
I wouldn't consider k-eps here because of low turbulence and its dissipation. kw-SST is a better choice. Also, refining the mesh might help in reducing dissipation. OJ |
May 8, 2013, 16:40 |
#8 | |
Mr CFD
Rep Power: 14 |
May 8, 2013, 16:57 |
#9 |
OJ
Rep Power: 20 |
I just suggested that omega based model with automatic wall function might fare better than epsilon based model with scalable wall function in this particular case, as he was considering. The use of k-eps is to be avoided in this case, primarily because of disspation it will introduce, eating up all the transient/turbulent instabilities that give rise to vortices. In cases of higher Re, k-eps may fare better.
OJ |
May 8, 2013, 22:48 |
#10 |
Rep Power: 143 |
Agreed, SST or k-w are the turbulence models to try here.
But second order time stepping is a MUST. You will need this. |
May 9, 2013, 06:36 |
#11 | |
Mr CFD
Rep Power: 14 |
Turbulence model for flow over a cylinder at Re=10000 | ojha.mayank485 | CFX | 18 | June 24, 2018 19:01 |
Flow over 2D Cylinder, Laminar and Turbulent | Tsr63 | FLUENT | 5 | November 13, 2014 12:13 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
