Non-Conservative Mass Flow Rate
Old   May 28, 2013, 21:50
Default Non-Conservative Mass Flow Rate
AJ Hunter
ajhunte is on a distinguished road
I am currently running a simulation with only one inlet and one outlet. I am getting kind of wonky data in the sense that the mass flow rate at the outlet is 45% less than that at the inlet. Is there a good reason that this should happen?
ABOUT MY SYSTEM:
Inlet --->Pipe ---> Smaller Diameter Pipe ---->Original Diameter Pipe----> Split in the system ---> recombine pipe ----> outlet
the split in the system is basically two pipes with equal diameter that form a circle. water goes in, splits, and then rejoins at the opposite side of the circle.
ajhunte is offline   Reply With Quote
Old   June 7, 2013, 10:53
OJ
oj.bulmer will become famous soon enough
The only reason can be that it hasn't converged
How do the mass imbalances look like?
OJ
oj.bulmer is offline   Reply With Quote
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 09:58
Mass flow rate at the outlet tejasvikrishna FLUENT 2 May 25, 2013 02:42
Mass flow rate through each cell Babakjingo Main CFD Forum 0 August 21, 2011 03:18
Mass flow rate sepidecent CFX 0 August 9, 2011 00:15
mass flow rate error Masood FLUENT 0 May 22, 2005 00:32
