October 8, 2014, 08:52 |
Tutorial file not found
#21 |
Christoph Heining
Rep Power: 14 |
Hello everyone,
I'm very interested in this tutorial because I'm working on a similar problem. Could you please post a newer link? Thanks a lot in advance Christoph |
February 6, 2015, 07:30 |
#22 | |
Diego Jaimes
Rep Power: 11 |
February 15, 2015, 19:56 |
#23 | ||
Petterson V Pramiu
Rep Power: 13 |
The tutorial in english it is ain https://drive.google.com/file/d/0Byu...ew?usp=sharing ppramiu Last edited by wyldckat; February 16, 2015 at 04:53. Reason: posted few minutes apart |
May 25, 2015, 11:16 |
#24 | |
GPJ
Rep Power: 11 |
Whatever is there in the above link i could not find any tutorial (English version) |
May 25, 2015, 14:42 |
#25 | |
Petterson V Pramiu
Rep Power: 13 |
I can send the tutorial in your email, ok? Please, write me - ppramiu@gmail.com []s |
May 26, 2015, 13:39 |
#26 | |
GPJ
Rep Power: 11 |
Setup could not find the file WinSDK_amd64\WinSDK_amd64.msi at any of the specified source locations G:\Setup Please attempt to resolve the problem and then start Windows SDK setup again. If you continue to have problems with this issue, please visit the SDK team support page at http://go.microsoft.com/fwlink/?LinkId=130245. The above prob ocuured when i tried to install the SDK setup |
September 8, 2016, 04:09 |
#27 | |
Ionut
In the above link i could not find any tutorial. Here is my email ionut_grec15@yahoo.com Thanks in advance |
September 8, 2016, 05:51 |
#28 |
Rep Power: 143 |
Tutorials on fortran in CFX are provided with the software. Have a look in the CFX documentation in the Modelling Guide for details.
November 7, 2016, 03:21 |
User fortran installation settings
#29 |
Hi all,
I found this link showing stepps needed to user fortran with CFX http://www.taochang.org/post/118.html It is chinese so use google translate to read the contents. I did not try yet, but I want to share this with you Regards, -Fahd |
November 7, 2016, 05:42 |
#30 | |
Petterson V Pramiu
Rep Power: 13 |
I visited the link and found the similar material with one that did in 2013. If you need the tutorial .pdf send me an email ppramiu@gmail.com I will gladly share with you. Regards, Ppramiu |
November 15, 2016, 20:26 |
Update Link and tutorials
#31 |
Petterson V Pramiu
Rep Power: 13 |
January 7, 2019, 08:22 |
#32 | |
Nazim
Rep Power: 12 |
Will it work for fortran95 as well and how to configure for fortran 95, |
January 7, 2019, 19:13 |
#33 |
Rep Power: 143 |
In the CFX installation manual it defines the versions of fortran which CFX supports. Using different versions of fortran to the supported version is going to make things difficult or impossible.
January 31, 2019, 05:32 |
#34 |
Petterson V Pramiu
Rep Power: 13 |
January 31, 2019, 12:19 |
#35 |
Rep Power: 32 |
Careful.
The documentation indicates which version of the Intel Fortran compiler is supported for a specific ANSYS CFX version. As long as you use the established/documented API's to transfer data between ANSYS CFX and your code, you should be able to use any flavor of Fortran coding, say F77/90/95/2008. What specifics of Fortran95 are you concerned with when coding for ANSYS CFX user Fortran connection? |
January 31, 2019, 12:26 |
#36 | |
Petterson V Pramiu
Rep Power: 13 |
Petterson Pramiu |
CFX 13.0 and fortran | zakir hussain | CFX | 16 | March 20, 2019 16:22 |
How to set environmental variables of Intel Fortran +CFX? | Christine MO | CFX | 0 | September 23, 2011 11:11 |
Help me about the cfx tutorial 19 air condition simulation~ | melody | CFX | 0 | August 16, 2011 03:36 |
Tutorial 11 of CFX: Flow Through a Butterfly Valve | safikhani_hamed | CFX | 1 | August 9, 2011 06:46 |
CFX and Fortran Compiler Integration | Rob | CFX | 2 | April 26, 2007 00:46 |
