Specify hybrid values for expressions in CFX-Post? |
August 12, 2010, 08:10 |
Joseph Tipton
Rep Power: 15 |
When creating expressions in CFX-Post, is it possible to force a hybrid calculation?
This question stems from my desire to calculate an average Nusselt number on the top surface of the outlet of a rectangular channel. To obtain the average heat flux I am using the following expression: lengthAve(Wall Heat Flux)@TopLineOut Here's the problem...
August 12, 2010, 18:36 |
Rep Power: 143 |
Hybrid/conservative value thing does not apply to surface integrals on boundary faces, but you are trying to do a line integral I assume on a boundary face. What I would consider doing is to replace your line integral with a surface integral where the surface you are integrating over is thin, so it is just about a line anyway. Then you evaluate the area integral and that should work fine.
July 20, 2013, 03:58 |
Hossein
Rep Power: 13 |
in CFX post go to:
Calculations ==> Function Calculator then set your request. For example lengthAve(Wall Heat Flux)@TopLineOut then at the bottom of Function Calculator tab, Press Hybrid button. after this CFD Post automatically uses Hybrid Values For your Expression |
cel expression, hybrid wall treatment |
Transient animation performance in CFX 5.5 POST | Sjoerd Romkes | CFX | 8 | February 5, 2013 14:53 |
Acceleration in CFX Post | LancelotCFD | CFX | 6 | November 4, 2008 11:06 |
Hybrid and Conservative values | alvio | CFX | 0 | September 2, 2008 08:46 |
Mapping manipulated pressures back into CFX Post | Molly | CFX | 0 | August 27, 2008 07:52 |
Assign new variable in CFX Post | Ben | CFX | 1 | August 25, 2008 14:59 |
