September 1, 2013, 12:58 |
enlargement of an artery
Shashwat
Rep Power: 14 |
Hi all
currently I am doing enlargement of coronary artery due to porosity of an artery wall .The flow is pulsate in nature.I want to clarify the following. Is this two way FSI or one way FSI ? or can we solve it this case in the CFX itself. Thank you |
September 1, 2013, 18:33 |
Rep Power: 143 |
The answer is self evident - if the flow affects the deformation but the deformation does not affect the flow it is one way. If the flow affects the deformation and the deformation affects the flow then it is two way.
I would think in your case it is almost certainly 2 way. |
September 1, 2013, 19:46 |
#3 | |
Shashwat
Rep Power: 14 |
Thank you so much. |
September 1, 2013, 21:08 |
Rep Power: 143 |
Are you sure the porosity/permeability is coupled to the fluid flow and motion? If it is not coupled then there is no point developing a simulation to do the coupling - and this will be far easier. Only model coupling on physics where there is, in fact, coupling.
September 2, 2013, 01:01 |
#5 | |
Shashwat
Rep Power: 14 |
Thank you |
September 2, 2013, 07:53 |
Rep Power: 143 |
You have to describe mathematically how all these couplings work before you can consider implementation.
So how is inflammation linked to porosity? What is the porosity a function of? You need to express the answers to these questions as mathematical functions. |
twoPhaseEulerFoam - sudden enlargement of circular pipe validation case | yanxiang | OpenFOAM Running, Solving & CFD | 17 | November 2, 2018 09:09 |
Porous artery and SST turbulence model | kmgraju | CFX | 13 | June 11, 2013 00:50 |
Clogged artery, Help! | kikeml | FLUENT | 3 | April 17, 2013 04:27 |
Dynamic mesh for 3D artery simulation | cheaklapomme | FLUENT | 1 | July 2, 2010 21:06 |
Grid generation for artery flow domain | Anne | Main CFD Forum | 2 | January 26, 2005 08:21 |
