September 28, 2013, 06:54 |
Rotating Reference Frame in CFX
SBR
Rep Power: 13 |
I'm new to CFX software. I've solved many problems in Fluent, but I have a question about the Moving Reference Frame in CFX. I want to calculate the aerodynamics loads on an airplane with spin. this can be done in Fluent by the Moving Reference Frame option. How can we do the same task in CFX without defining two fluid zones (inner and outer)? In my opinion, we should define two fluid zones and define a rotation speed for inner zone (in CFX). Thanks in advance. |
September 30, 2013, 18:32 |
Rep Power: 143 |
If you are modelling a spinning aircraft in a far field - so there is no objects in the stationary field - then you can model this with just a single rotating frame of reference. No need for a stationary frame of reference.
October 1, 2013, 05:36 |
SBR
Rep Power: 13 |
Thank you very much for your reply.
Is the following settings true for the purpose of rotating frame of reference? - Domain motion: rotating (with angular velocity: 5 rad s^-1) - Inlet / Outlet frame type: Rotating I can't obtain a converged solution with the mentioned settings. Thanks in advance... |
October 1, 2013, 20:46 |
Rep Power: 143 |
You might need to set the boundaries as counter-rotating so they are as expected in the stationary frame of reference.
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
how to treat the rotating zone in multiple reference frame (MRF) | Jiuan | FLUENT | 4 | May 24, 2010 21:58 |
Multiphase in rotating reference frame | M_W | FLUENT | 0 | March 18, 2009 10:24 |
Gravity in single rotating reference frame | QinxueTan | FLUENT | 0 | May 7, 2008 06:59 |
Rotating Reference frame | Ketan | FLUENT | 0 | May 25, 2007 11:58 |
