September 29, 2013, 10:17 |
Error Simmetry
Loris
Rep Power: 12 |
Hello everyone!
I have done mesh with ICEM, then I have imported it in Ansys CFX 14.0. After setting all things in CFX-Pre, I start the simulation, but there is a problem: |ERROR #002100013 has occurred in subroutine Chk_Splane. | | Message: | | The symmetry boundary condition requires that the boundary patch | | mesh faces form a plane or axis. However, face set 3 in the | | symmetry boundary patch | | | | PARETE_SYM_2 | | | | is not in a strict plane, which means that at least one of its | | faces is not parallel to the others. To make the solver run | | you can do one of the following: | | | | (1) Make sure that this symmetry boundary patch is in a plane or | | axis by checking and regenerating the mesh. | | (2) If the symmetry boundary patch is an axis rather than a | | plane, change the tolerance of the degeneracy check by | | increasing the value of the Solver Expert Parameter | | 'degeneracy check tolerance' (the default value is 1.e-4). | | (3) Increase the value of the Solver Expert Parameter | | 'vector parallel tolerance' (the default value is 1 deg.). | | Note that the accuracy of the symmetry condition may decrease | | as the tolerance is increased. This is because the tolerance | | is the number of degrees that a mesh face normal is allowed | | to deviate from the average normal for the entire face set. | This is the error message that I received. After reading some past messages about this error, I have found this reply "In pre-mesh, in ICEM, click on "No Projection"". I tried this and the first time that I have done that, the problem is solved... but, now this solution does not work anymore.. Can you help me? I do not have particular geometry... one rectangular channel with a block at circa half length channel... in CFX, I have to analyze this problem in 2D... I read many post online... I also tried to apply the suggestions that Ansys gives me but in every cases, I do not succeed to solve the problem. I have found also post that it said "Click in ICEM tab Global Mesh Setup and then go to Edge Criterion...change value from 0.2 to 0.05" but nothing... Last edited by Loris88; September 29, 2013 at 12:20. Reason: Complete Post |
error #002100013 |
