October 10, 2013, 02:51 |
CFX Reduce transient output file size
Rep Power: 12 |
Hello to everybody,
first: it's a great Forum, many thanks for the helpful advices! I've a question concerning the CFX transient output files. On transient calculations and with the default settings the files become bigger over the time because every file saves the whole convergence history. For example I start with my 2D model with a file size of 40MB and after 500 transient files it's 200MB. Is it possible to switch that off? I only want to save my results. Thanks Thomas |
October 10, 2013, 05:05 |
Rep Power: 143 |
You must be saving full results files. Make the transient results selected variables only and they will be much smaller - but you should save a full one every now and again to restart from if the run crashes.
October 10, 2013, 05:27 |
Rep Power: 12 |
Oh, OK, that makes sense. If I select "selected variables" I can't restart from these Points right?
Another question: If my run crashes and I restart my calculation with the last transient file the solver produces a new Folder for the following result files. Is there a way to connect the files of the different folders in CFX Post? |
October 10, 2013, 05:34 |
Rep Power: 143 |
That's right, unless you add enough variables such that it can restart from it.
If you are recovering from a crashed run you are going to have to do the post processing in two sections (if you are doing things in time). |
October 10, 2013, 05:37 |
Rep Power: 12 |
OK many thanks for your reply!
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
Reduce output file size!! | Jonac | CFX | 1 | September 15, 2000 03:24 |
