What is the best way to describe a liquid material?
Old   October 31, 2013, 09:02
Default What is the best way to describe a liquid material?
Lee
kiwishall is on a distinguished road
As the title said, when I want to insert a new material of liquid in CFX, what is the beat way? General ? Table? Or what? The predefined liquid materials in CFX were described with NASA format or ZERO PRESSURE POLYNOMIAL format. But how could I get the parameters of the material that I want?
Thank you in advance.
kiwishall is offline   Reply With Quote
Old   October 31, 2013, 16:13
There is no general best way, you use the method which works best for your application. Many models do not need (or do not have) accurate material properties so constant viscosity and density is just fine. If you need variable viscosity or density then it depends on what material property data you have, what accuracy you need, numerical stability and lots of other factors.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Material Properties for Sat. Liquid and Sat. Vapor Blackhawks84 FLUENT 0 September 17, 2012 19:11
error message cuteapathy CFX 14 March 20, 2012 06:45
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
