Error when trying to import a CFX-Mesh into CFX-Pre
Old   January 17, 2011, 15:16
Unhappy Error when trying to import a CFX-Mesh into CFX-Pre
audrey is on a distinguished road
I have to disclose that I am an absolute newbie and this might be a silly question... I am working through one of the CFX tutorials, but I can't seem to import the mesh I created into CFX-Pre. (I am using version 12.1 of Ansys workbench and CFX-Pre.)
I created the geometry and mesh as described in the tutorial. Ansys workbench shows that both elements are valid and up-to-date. When I launch CFX-Pre, the mesh file doesn't load and instead I get the following error message:
CFX-Pre Application Error
ERROR
It was not possible to extract any mesh from the file:
/home/Research files/CFD/Tutorial/Tutorial_files/dp0/CFX/MECH/CFX1.cmdb.
Please note that a Workbench installation is normally required to import this type of file.
When I try to import the CFX-mesh file instead, I get the following error message:
ERROR
/home/Research files/CFD/Tutorial/Tutorial_files/dp0/CFX/CFX/Fluid Flow.cfx.
I have tried starting a new project and importing the geometry and mesh files, as well as rebuilding the geometry and mesh files from scratch, but it didn't help. The solution might be obvious, but I assumed that carefully following the tutorial instructions should prevent errors from happening...
Thanks,
Audrey
audrey is offline   Reply With Quote
Old   January 18, 2011, 17:07
Edmund Singer P.E.
singer1812 is on a distinguished road
Not sure what is causing your errors, but perhaps you can try going up to File->Export->Mesh and export it as a Fluent mesh (*.msh) file.
Then in pre, choose import mesh and import it as a fluent mesh.
singer1812 is offline   Reply With Quote
Old   January 19, 2011, 07:06
Thanks for the suggestion, singer1812. It was a bit fiddly, but it worked. If anybody has any idea what was causing the errors in the first place, though, I wouldn't mind finding out...
Old   January 26, 2011, 08:50
It was a beginner's mistake: I had a space in one of my folder names... ("Research files"). Apparently, that trips up CFX on Linux really badly.
Old   October 23, 2013, 14:46
ARS
AS
ARS is on a distinguished road
Still the .msh file is not importing and showing
Error: Null Domain Pointer
ARS is offline   Reply With Quote
Old   November 17, 2013, 14:54
Default resolved
PYJG is on a distinguished road
I was able to resolve the error by updating gtmDSDBReader.exe that was missing.
PYJG is offline   Reply With Quote
cfx-mesh, import error
import mesh from CFX george FLUENT 8 February 6, 2019 03:43
Import Mesh from CFX TurboGrid Txema FLUENT 0 February 9, 2007 03:45
icem: import tecplot mesh David CFX 4 August 9, 2006 08:30
hex mesh using cfx mesh. mehul CFX 3 December 12, 2005 22:06
Mesh: Import to CFX DAK565656 CFX 7 November 19, 2005 19:42
