November 27, 2013, 11:04 |
Axial turbine simulation - BC setup problem
Bharath kumar
Rep Power: 17 |
Hi to all,
I am new to turbo machinary simulation.I am doing an axial turbine multistage cfd analysis.At first i am doing 1st stage only 1) In this i setup run initially using CFX turbo mode.Interface type I kept Stage Rotor and I kept all other BC's as default.For this i am getting good converged results(1e-5). 2) Later in 1st case i found that, Rotor shroud wall BC is counter rotating .In 2nd case, i changed it (rotor shroud wall) to rotating wall BC .Now i am getting oscillating behavior (periodic) in solver. In both cases stator is stationary and rotor is rotating.All other BC's are same. could anybody explain me which one is right and why the oscillating behavior in 2nd case. Thanks in advance |
November 27, 2013, 16:36 |
Rep Power: 143 |
FAQ: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Looks like your change in BC moved the simulation into a more numerically or physically unstable regime. |
November 28, 2013, 00:14 |
Bharath kumar
Rep Power: 17 |
Thanks ghorrocks
What you told i understood. 1) What i am not getting is which direction is right one? 2) And another query is I am getting about 10% more mass flow at Rotor outlet (Stage1) with good converged results.Is it correct behaviour for the turbine? |
November 28, 2013, 00:49 |
Rep Power: 143 |
Can you post an image of what you are modelling and where the boundaries are?
November 28, 2013, 06:07 |
Bharath kumar
Rep Power: 17 |
Thanks ghorrocks
Sorry I can't post images as it is official document (Confidential). But i understand the things.Actually i mean to say whether Rotor shroud wall velocity (influence on flow) should be uncheked in cfx pre, if it doesn't have clearance.Now i am clear. Thanks for your reply. |
Axial Flow Turbine Problem | Manish | FLUENT | 1 | February 14, 2017 03:46 |
Wind turbine simulation in Ansys CFX | aalbanesi | CFX | 50 | January 18, 2017 12:02 |
Problem in initializing transient simulation with a finer mesh | sidd | CFX | 8 | April 29, 2016 02:25 |
Dynamic mesh simulation (pimpleDyMFoam) problem | sidlof | OpenFOAM Running, Solving & CFD | 6 | April 12, 2013 11:24 |
Problem with interface in a wind turbine simulation | be_inspired | FLUENT | 2 | March 7, 2011 23:46 |
