CFX Reverse flow problem even if open boundary used |
December 5, 2013, 05:33 |
Rohit Adhav IIT Madras
Rep Power: 12 |
I am Rohit
I am performing simulation of water flowing through centrifugal pump impeller (only impeller is considered) . i am getting flow rate = zero and in report reverse flow is observed. i.e i am getting completely wrang results. even if i use open boundary condition at outlet. same problem appears for 38000 elements, 70000 elements and 1 lac elements of mesh. (structured mesh i created using turbogrid) can anybody help me in this regard.? |
December 5, 2013, 06:35 |
Stuart
Rep Power: 25 |
What happens if you move your fluid domain boundaries further away from the impeller? See // Modeling Guide // 2. Boundary Condition Modeling // 2.3. Using Boundary Conditions // 2.3.3. Using Inlets, Outlets and Openings Figs 2.1 to 2.3 in the CFX v14.5 Help.
December 5, 2013, 16:01 |
Rep Power: 143 |
Have you checked you are at the right operating point? That means the flow rate and pressures are expected to work for the pump design and RPM. Also, are you sure the impeller is rotating in the correct direction?
cfx, open boundary, reverse flow |
Question on the boundary condition for open channel flow, please help! | ripperjack | OpenFOAM Running, Solving & CFD | 0 | September 13, 2013 11:44 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
