porous domain
Old   February 11, 2014, 08:59
Default porous domain
lauda
lauda is on a distinguished road
Hello there,
I'm trying to model a heat exchanger (HX) as porous model. The HX consists of a box with a large number of pipes mainly parallel to each other.. I was thinking to use the isotropic loss option of the porous domain. I have then calculated the liner and quadratic resistance coefficients (CR1 and CR2 in CFX-theory tutorial). I would appreciate if you could confirm that the equations I have used (see below) are correct.
CR1 = K_loss * rho / 2 = Dp / (L*v**2)
where rho is the density, Dp is pressure drop across the HX, L is the HX lenght and v is the stream flow velocity at the HX inlet.
CR2= mu / K_perm = dP / (L * V_s)
where V_s= volume flow rate/cross sectional area.
thanks for your help
lauda is offline   Reply With Quote
porous body
Radiation at interface between fluid and porous domain Hitch8 CFX 19 April 20, 2015 06:24
Floating point exception: Zero divide liladhar CFX 11 December 16, 2013 04:07
Implementation of a porous domain megacrout OpenFOAM 1 January 12, 2012 07:02
Porous domain set-up from single pressure loss value siw CFX 1 December 8, 2011 16:36
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
