March 17, 2014, 10:41 |
point on surface
tb_cfd
Rep Power: 12 |
how can i create points on the surface of a 3D-wing of an axial fan? I want to evaluate the pressure on the leading edge for example. Is there any function on cfd-post where i can pic the nodes on the surface. After defining the points i want to export the x-, y- and z-coordinates by File -> Export. Hopefully someone can help! |
March 20, 2014, 01:53 |
Bharath kumar
Rep Power: 17 |
You can use Probe in CFD post.
cfd-post, point, post, surface |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
Creation of surface and point | itsme_kit | FLUENT | 0 | December 9, 2013 20:23 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 01:10 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
journal command for surface Point and Normal | Ralf Schmidt | FLUENT | 0 | January 4, 2006 02:48 |
