point on surface
Old   March 17, 2014, 10:41
Default point on surface
tb_cfd
tb_cfd is on a distinguished road
how can i create points on the surface of a 3D-wing of an axial fan? I want to evaluate the pressure on the leading edge for example. Is there any function on cfd-post where i can pic the nodes on the surface. After defining the points i want to export the x-, y- and z-coordinates by File -> Export.
Hopefully someone can help!
tb_cfd is offline   Reply With Quote
Old   March 20, 2014, 01:53
Bharath kumar
bharath is on a distinguished road
You can use Probe in CFD post.
bharath is offline   Reply With Quote
cfd-post, point, post, surface
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
Creation of surface and point itsme_kit FLUENT 0 December 9, 2013 20:23
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
journal command for surface Point and Normal Ralf Schmidt FLUENT 0 January 4, 2006 02:48
