April 12, 2014, 08:06 |
Setting up static pressure
Glenn Ong
Rep Power: 12 |
Hi everyone, I'm relatively new to using CFX and I need some assistance with setting up the static pressure in the fluid domain.
I want to set the static pressure of my domain to that of the underwater pressure, ie. Atmospheric + rho*g*z where the variable in this equation is z. So my question is, where do I key in this equation? Is it under initialization>static pressure>relative pressure? Any help is greatly appreciated. Thanks |
April 12, 2014, 15:35 |
Rep Power: 16 |
First, create an expression “main menu->insert->expression”, and then use it in the domain initialization.
April 13, 2014, 06:38 |
Rep Power: 143 |
Abou describes how to add an equation.
But my question is why do you want to do this? If you read the documentation you will find in a buoyant simulation the pressure variable already have the hydrostatic component removed from it. The absolute pressure contains the hydrostatic component (and the reference pressure offset). |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 10:34 |
Average static Pressure | san.pirate | CFX | 35 | September 27, 2020 11:47 |
Average static pressure BCs and aircore in cyclone | KM | CFX | 2 | December 17, 2007 20:50 |
Total pressure to static pressure ratio | roadracer | Siemens | 1 | April 17, 2003 05:31 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
