Apply heat souce on moving gas/liquid interface?
Old   April 23, 2014, 13:50
Default Apply heat souce on moving gas/liquid interface?
cfdkc is on a distinguished road
Hi all,
I am using Ansys CFX to simulate laser weld molten pool flow. The laser heat needs to be applied on the gas/liquid metal interface, which is moving as liquid metal evaporates. My question is how to track the interface and apply the heat source there? Can the interface location be accessed as an internal variable, similar to gas.vf and liquid.vf?
Thanks for your help.
cfdkc
cfdkc is offline   Reply With Quote
Old   April 24, 2014, 03:51
Some ideas:
You could model the laser with a radiation model. Then the heating would occur at the correct place when you have set the absorbance, reflectivity and everything else.
You could assume the surface occurs when the volume fraction is between 0.1 and 0.9 (for example). This approach only works if your interface is well defined.
Radiation interface hinca CFX 15 January 26, 2014 17:11
How to define the heat flux in the interior interface between two phases fangdian FLUENT 1 November 18, 2013 07:23
Heat Flux at Internal walls or Fluid Solid Interface Mahi CFX 3 October 1, 2012 02:18
modeling interface in conjugate heat transfer Vivek FLUENT 5 October 12, 2007 05:43
How to apply heat flux condition L. Zhu FLUENT 2 January 8, 2003 10:16
