Linear and quadratic loss coefficients of porous domain
Old   May 21, 2014, 09:11
Default Linear and quadratic loss coefficients of porous domain
Daniel Laki
LD696 is on a distinguished road
Hi all,
I'm modelling a valve which has a filter in it. Obviously I'd like to replace the filter with a porous domain, using the directional loss model and I'd define the streamwise loss with the linear and quadratic resistance coefficients.
I have set up a parameter study to find the coefficients for my two working fluids (oil at -20°C and 130°C) by calculating the pressure loss through a simplified filter model for the known mass flow rates.
Now my problem is that I can find a combination of these coefficients that can reproduce the correct pressure loss for all mass flow rates for the cold oil. However for the hot oil I have to set different coefficient values for every mass flow rate. I have some previous experience with this problem, as this is the second such project of mine. In the previous project I had a different kind of oil at 0°C and 90°C and I was able to find the correct coefficient values. So only the 130°C oil does not seem to "work".
What can cause this problem?
LD696 is offline   Reply With Quote
Old   May 21, 2014, 15:08
Edmund Singer P.E.
singer1812 is on a distinguished road
What is not working?
singer1812 is offline   Reply With Quote
Help in porosity for knitted fabric??? Linear or Quadratic resistance coeff SS460 CFX 13 September 22, 2011 11:43
Momentum source / porous loss ijk CFX 5 May 20, 2011 10:30
Porous Domain ijk CFX 1 August 30, 2010 19:03
porous medium - defining loss coeff for two fluids sudhakar CFX 0 December 9, 2006 08:11
porous domain problem sudhakar CFX 6 November 29, 2006 09:48
