June 12, 2014, 09:06 |
how to draw surface streamline in CFD-post?
Rep Power: 13 |
I want to draw surface streamline on the 3d-wing surface, but when i use the surface streamline in CFD-POST, it didn't work, i can't see any streamline. i know the velocity on the 3d-wing surface is zero, but the User's Guide shows the program can do this job. ps:i know how to use CFD-post to generate 3d streameline.
who can help me |
June 12, 2014, 18:38 |
Rep Power: 143 |
I suspect CFD-Post uses wall shear to generate the surface streamlines. Have you included wall shear in your output file?
June 13, 2014, 01:11 |
Rep Power: 13 |
thank you for your advice,I have alreday draw the surface streamline.Just like you said that CFD-Post uses wall shear to generate the surface streamlines and the wall shear information should be given. when generate surface streamlines in the software, the wall shear in the variable list should be chosen rather than velocity then surface streamline is visible.
surface streamline |
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. | hda | ANSYS Meshing & Geometry | 5 | October 24, 2016 09:26 |
static enthalpy calculation in CFD Post | newbie384 | CFX | 2 | March 22, 2014 07:28 |
Automated post processing using CFD Post | shreyasr | ANSYS | 0 | January 28, 2013 06:21 |
user surface in post | xinzhangabc | CFX | 0 | February 24, 2005 06:29 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
