CFX Multiphase - Fluid-fluid heat transfer
Old   June 14, 2014, 06:21
Default CFX Multiphase - Fluid-fluid heat transfer
Nasir Mehmood
nasir is on a distinguished road
Dear Experts
I need help and guidance from you. Need to do simulation in CFX. I have a coil
and hot air is entering in that coil at 750 K with inlet velocity of 0.2 m/sec and exiting into the atmosphere. That coil is enclosed inside a drum filled with water at 298.15 K, and water is closed inside the cylinder. Need to simulate the heat transfer from coil to water.
It may be a simple problem for you all but for me its difficult.
What i have done so far in CFX.
I made two domains in CFX, one is air and other is water. As both the fluid are separated and not touching each other i am not using homogeneous.
What is the mistake i am making ....... plz help
CCL file is attached can
nasir is offline   Reply With Quote
cfx, fluid fluid heat transfer, heat transfer, multiphase
Heat Transfer Solid to Fluid [CFX] skaboy607 CFX 15 January 11, 2021 19:19
Porous domain:Interfacial area density and heat transfer coefficient l.te CFX 2 May 17, 2014 23:45
Heat Transfer mechanisms tafaugl CFX 1 November 7, 2012 18:46
Solid / Fluid Heat Transfer Koranten FLUENT 3 March 19, 2011 07:21
