ERR #002100004 Out_Scales_Flu
Like Tree1Likes
  • 1 Post By Deepthi
Old   March 12, 2004, 09:02
Default ERR #002100004 Out_Scales_Flu
Deepthi
I am modelling a multiple domain problem,(simulating aircraft wing). i have two domains(main domain:box to simulate windtunnel at inlet speed 6.812m/sec; rotor domain rotating at 1480rpm)
I am getting the following message in out file irrespective of model(SST,KW,RSS) and meshing refinement, timestep changed.
--------------------------------------------- ERROR #002100004 has occurred in subroutine Out_Scales_Flu. Message: The Reynolds number is outside of the range expected based on the Option selected for the TURBULENCE MODEL. Check this setting, the values of the properties, mesh scale, consistency of units and solution values in the input file. Execution will proceed. -----------------------------------------------
Im getting converged solution, but after post processing my results were not very accurate. Can anyone tell me if this is cause and how i can solve it.
Thanks in Advance, Deepthi.
vmtlv likes this.
Old   August 7, 2014, 02:47
nguyentuan
vmtlv is on a distinguished road
I have met ,too.
How to fix this errors ?
My results were not accurate. (=_=)
@Deepthi: Have you solved it yet ?
vmtlv is offline   Reply With Quote
Old   August 7, 2014, 05:43
Default define rotor
Martin_Sz's Avatar
Marcin
Martin_Sz is on a distinguished road
Hi
How do You define rotor?
Solid Domain or immersed solid
If You dont to analyze temperature on rotor try immersed solid
Best regard
Martin_Sz is offline   Reply With Quote
Old   April 3, 2015, 11:47
Pavel
powpawell is on a distinguished road
This is not going to help now, but keep it for reference. There is an explanation here.
Enjoy
powpawell is offline   Reply With Quote
error #002100004 jai CFX 1 December 31, 2009 14:42
dynamic meshing : an err message Prasad Laxman Kane FLUENT 1 August 6, 2003 02:06
Err: can't allocate fine level coefficient matrix Chris FLUENT 2 March 7, 2003 03:16
