August 6, 2014, 08:06 |
CFX SCO2 turbine temperature
Cafard
Rep Power: 11 |
Hi all,
I try to simulate a SCO2 radial turbine,and the condition are: 1.)Inlet:1MPa(static),reference pressure:12MPa,500K(static) 2.)Outlet:0.01 kg/s (1passage [total:11]) 3.)Material>reference state property> reference temperature:500K reference pressure:12MPa 4.)time scale:2.5e-4 5.)model size=60mm H=30mm 6.)mesh:1.2e5 nodes(quality good) The simulate result was finish at timesteps 5000,residuals was 1e-6 and no vibration. The boundary condition: a.)Outlet pressure : 0.86MPa b.)Outlet temperature : 499K c.)max. velocity(inlet) : 40 m/s My question is why the outlet temperature still near 500k,temperature shuld decrease.I have read the Ansys FAQ,but still not solve the question. By the way,is the reference state property right? |
August 6, 2014, 08:19 |
Rep Power: 143 |
Then you have not modelled the heat transfer correctly. What wall boundary conditions are you using? What temperature are you expecting at the outlet? Why are you expecting it?
August 6, 2014, 09:30 |
Rep Power: 32 |
May I ask why are you using Static Temperature inlet condition ?
Similarly, why static pressure and not Total Pressure ? I assume you meant 1MPa gauge pressure since you are using a reference pressure of 12MPa, correct ? Not sure what exact material you are using (incompressible, or compressible ?). An incompressible fluid will pass through the turbine and the temperature rise will be minimal (if any). Have you tried running the "Axial Turbine" tutorial provided in the installation ? |
August 6, 2014, 11:02 |
Cafard
Rep Power: 11 |
the wall condition is adibadic
because I want to simulate supercritical CO2,so I use real gas material which is compressible gas. by the reference paper (SCO2 brayton cycle),after the turbine the outlet temperature should decrease,but not just decrease 1K the static state condition just I set,by the way,could I solve my question by set total state condition ? |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Simulation of Water Turbine with CFX | hydroturbines | CFX | 0 | July 23, 2014 15:58 |
convergenceof natural convection prob. in cfx | cpkewat | CFX | 15 | January 31, 2014 06:29 |
Verifying results for a wind turbine blade simulation in ANSYS CFX | Joystix | CFX | 3 | April 27, 2012 17:52 |
simulation Axial flow turbine using CFX | dia aisa | CFX | 3 | May 2, 2008 02:45 |
