Boundaries conditions to pump characterization
Old   September 15, 2014, 06:37
Default Boundaries conditions to pump characterization
SteJor
stephane.jorand is on a distinguished road
I have to characterize a centrifugal pump by CFD but I don't have any boundaries conditions.
I just know the pump rotation is between 500 and 2000 rpm.
Is it right to set total pressure = 0 at inlet and static pressure = 0 at outlet and then the solver give me the massflow and the pressure developed by the pump?
stephane.jorand is offline   Reply With Quote
Old   September 15, 2014, 07:43
No, this does not sound right.
Pumps operate on a pump curve which relates flow rate to pressure difference. Where on the curve you sit will depend on the pump, the motor power driving it and the system it is connected to.
So doing a single simulation at essentially no pressure difference sounds pretty meaningless. You need to load the pump up with either a flow rate or pressure difference representative of the system it will be running in, and that will give you a single point on the pressure versus flow rate curve for the pump.
Linux commands to define boundary conditions at velocity-inlet & wall boundaries saayo3 Fluent UDF and Scheme Programming 1 June 29, 2013 12:33
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
boundaries conditions for an oil -gas separator juliom CFX 4 May 15, 2011 07:11
Wall Heat Flux Boundaries conditions Abigail FLUENT 2 July 24, 2007 09:34
periodic boundaries - flow through a net PK FLUENT 0 July 12, 2007 11:58
